Repair guides and disassembly information for laptops manufactured by ASUS.
Wi-Fi always stays off. How to enable?
Hi, my UX305FA (Win10) has this red X on its Wi-Fi symbol, it saids "Not connected - No connections are available" when mouse over. The wi-fi toggle in NETWORK & INTERNET settings always stay off. And the wifi device option is grey-out in the Airplane mode page. Network adaptor is enabled correctly in Device Manager. It seems like the wifi is disabled by some kind of hardware switch.
I have try booting into Ubuntu (by usb) to confirm. Problem remains, and the wifi message is "Wi-Fi is disabled by hardware switch" .
Does anyone know if there is any hardware Fn key on this laptop to enable the wifi? There is none that I can find. The only network related Fn key is the airplane mode Fn+F2.
Any suggestion?
Asus zenbook ux305FA
Score 3
2 Comments
For anyone having a problem with ASUS laptops, F5R specifically, I personally never noticed that I moved the _physical_ switch (rather than the Fn+F2 combo) on the left side of the notebook which hardware-locked the wifi. Curiously, on a cold start in Ubuntu/Elementary wifi works, but after a reboot it doesn't. F5R owners make sure to check that the switch is in on position.
by
thanks mate you saved me another hour of chasing my tail. Cheers
by
Add a comment
Chosen Solution
Hi,
According to the user manual in the BIOS area under the Security tab -- I/O Interface security there is a Wireless Network Interface option to lock or unlock. The manual shows it as unlock you might want to check and see if yours is in the lock position.
Score 2
13 Comments:
It is in [Unlock] position.
by
hi,
can you turn airplane mode on and off using Fn F2?
by
Yes, airplane mode is functional.
Bluetooth is grey out when airplane mode is ON.
Wifi is grey out no matter what.
by
maybe you could try
make sure airplane mode is off
go into bios and "lock" wireless network save change, boot into Win check that WiFi is greyed out.
then go back into bios and unlock wireless network save change, boot into Win and check
basically toggle the setting
by
found this on the Asus website
http://www.asus.com/us/Notebooks/ASUS-ZE...
driver download for wireless - asus wireless don't know if this is yours -a driver to switch Airplane mode (wireless ) on/off dated 2015 /08/14
might be worth a look
by
Show 8 more comments
Add a comment
Your wireless controller may be broken our have loose connection
Add a comment
Hi, I had the same problem.
I tried re-installing the WiFi driver. Still the same. My netbook is a dual boot seashell series. I opened the program with Asus Express Gate Cloud (firefox), went to settings , swithed the WiFi off & on & the WiFi switched back on. I was playing in this area a week or two before trying to get it to work & I must have switched the WiFi off.
Add a comment
Add your answer
Fan will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 22
Past 30 Days: 112
All Time: 91,387
